 Vẽ lò xo trong SolidWorks
Bài gửiTiêu đề: Vẽ lò xo trong SolidWorks   22/10/2010, 09:15
1. Click New (File>New) , click Part , OK .
2. Click Option (Tools>Option…) , select Document Properties tab. Select Units , under Unit System select IPS (inch, pound, second) OK.
3. Select Top Plane , from lower left menu select Normal To.
4. Click Sketch in Command Manager, click Circle . As you can see on upper right corner sketch icon appear indicate that you’re on sketch mode.
5. Pick Origin point as starting point, drag to right hand side no need to be exact the size will define in later step. Press keyboard ESC to end circle sketch.
Note: There is two type line generated by in sketching, the one with black line and blue line. Black line is line that fully defined and blue line is under defined..
6. Define sketch with dimension. Click Smart Dimension , and start dimensioning pick circle edge and set to 0.50in . Press keyboard ESC to end smart dimension.
7. Change display to Isometric view.
8. Insert coil, Click Insert>Curve>Helix/Spiral .
9. Press F to zoom fit, set Parameters Constant Pitch , Pitch 0.10in Revolutions 4 , Start angle 0.0deg and .
10. Click to Right Plane , click Normal To .
11. Click Sketch , click Circle . Sketch circle at start point, then click Smart dimension set circle diameter to 0.05in .
12. Click exit sketch. Click Features and activate features menu. Click Swept Boss/Base and set Profile to Sketch2 by click on circle sketch and set Path by click helix path and .
13. Change display to Isometric view.
14. Press F to zoom fit.
Done. Pat yourself on back.
Theo oto-hui.com
vosuthe
Tổng số bài gửi : 10
Bài gửiTiêu đề: Re: Vẽ lò xo trong SolidWorks   11/4/2013, 22:10
cách này em cũng vẽ rồi .cũng rất hay.
ah anh cho em hỏi là:em vẽ lò xong rồi.sau đó vào môi trường lắp ráp.em muốn đặt một vật lên một đầu của lò xò.và em muốn khi vật này đè xuống thì lò xo cũng phải nén lại thì phải làm sao anh ?
Bài gửiTiêu đề: Re: Vẽ lò xo trong SolidWorks   12/4/2013, 11:23
vosuthe đã viết:
Đây chỉ là một chi tiết bình thường, không có khả năng đó.
Bạn phải tạo lò xo trong môi trường động lực học.
vosuthe
Bài gửiTiêu đề: Re: Vẽ lò xo trong SolidWorks   12/4/2013, 14:06
Bác có thể chỉ rõ hơn tý được không?tức là mình vẫn mỡ soliwork lên ,sau đó vào phần nào để vẽ vậy Bác?Bác chỉ cái hướng đi cho em với.
