 Download các Videos học Inventor
Bài gửiTiêu đề: Download các Videos học Inventor   15/11/2010, 13:28
Adaptive Gas Line using 3d Sweeps
Adaptive Gas Line using intermediate fitting
3D Spline by intersecting two 2D Splines
Adding text to parts
Adaptive Coil Spring Animation - Adaptive Coil Spring Inventor Files
How to make an Adaptive Coil Spring
Create an Adaptive Flexible Hose (R8+)
Cutting an internal Helix on a Mill using an angle head and rotary table (CNC)
Place a dimension on the center of a slot
Adding components to a Tweak in Presentations file
TahlCAM running in AutoCAD from TahlInc
Mobius Loop in Inventor
Positionable Hole on Cylinder
Positionable Hole on Cylinder pointing to a target point on another surface
R9 Pro Piping using Swagelok library I have in development.
Create a Color (R8)
Spline Between Parts
Copy / Paste Feature (Cabriole Leg) as an execise, how would you design it such that everything is controlled by one sketch as shown in this animation CabrioleLegStretch ?
Drill Holes at an angle to a face
Multiple Adaptive Springs. Assembly created from spring templates on cbliss.com hardware page (MS WMV9 codec)
Torbjørn's Lego Caterpillar Track's animated with slack.
Make adaptive Bellows from Template link to the Bellows template part
Create a "mid plane" from non parallel faces (or planes) as a single nested work features.
» CHẤT LƯỢNG VIDEO CHO PHÁT SÓNG HD
