| | Các videos hướng dẫn tạo hình khối Mass | |
| Tác giả | Thông điệp |
Tổng số bài gửi : 1644 Points : 3706 Reputation : 194 Join date : 07/04/2009
 | Tiêu đề: Các videos hướng dẫn tạo hình khối Mass 25/5/2011, 21:56 | |
| [ I am still surprised by the amount of questions and queries I get from users who are trying / starting to use Revit’s conceptual massing tools in either RAC 2010 or RAC 2011. The most common queries relate to how you actually create a particular form. I am suppose pre 2010 it was straight forward as we had extrude, revolve, sweep, blend and swept blend. The way you used these form making tools was very explicit; need to create an extruded form? Then use the extrude tool. Revit 2010 changed all that with a far more flexible approach to form making, but to some extent it tossed away the rule book and I believe that is what has confused some users. If you don’t do a lot of massing in Revit, this new paradigm can also lead to confusion and a certain amount of head banging!! I’ve had experienced Revit users get totally stumped when creating even the most basic forms. Once you understand the behaviour and the philosophy to form making, creating complex forms gets a lot easier. So it made sense to create a series of short videos which explained how to create some common forms in Revits conceptual design environment. Experienced users who use the tools will know all this, but for those that don’t, I hope this is of assistance. I have deliberately avoided any voice over, so you force yourself to review the tools and commands being picked. It is all about creating the forms and I deliberately does not delved into model lines versus reference lines, pure geometry only. I am sure there are many ways to create some of these forms, but these in my view these are the most obvious steps. You will find videos which you how to….. - Extrude
- Revolve
- Blend
- Sweep
- Swept Blend
- Cone
- Dome
- Sphere
- Torus
- Loft 1
- Loft 2
- Pyramid
1. Extrude 2. Revolve 3. Blend 4. Sweep 5. Swept Blend 6. Cone 7. Dome 8. Sphere 9. Torus 10. Loft 1 11. Loft 2 12. Pyramid |
|  | | chinks
Tổng số bài gửi : 9 Points : 11 Reputation : 2 Join date : 26/05/2011
 | Tiêu đề: Re: Các videos hướng dẫn tạo hình khối Mass 26/5/2011, 14:56 | |
|  | | quockhanh
Tổng số bài gửi : 13 Points : 12 Reputation : -1 Join date : 15/06/2011
 | Tiêu đề: Re: Các videos hướng dẫn tạo hình khối Mass 18/6/2011, 16:02 | |
| thầy ơi vô đâu để mở các family này vậy em không biết mở cài nào để cho có màn hình giống như trogn này. thầy giúp em với |
|  | | Admin Admin
 | Tiêu đề: Re: Các videos hướng dẫn tạo hình khối Mass 21/6/2011, 09:00 | |
| Bạn vào New -> Conceptual Mass |
|  | | coldboy
Tổng số bài gửi : 1 Points : 1 Reputation : 0 Join date : 30/08/2011
 | Tiêu đề: Re: Các videos hướng dẫn tạo hình khối Mass 30/8/2011, 22:47 | |
| Thầy ơi..tự học thì nên học như thế nào cho có hệ thống ạ?
|  | | quyetthanhkts
Tổng số bài gửi : 3 Points : 3 Reputation : 0 Join date : 02/03/2011
 | Tiêu đề: Re: Các videos hướng dẫn tạo hình khối Mass 23/7/2012, 20:33 | |
| Em khâm phục thầy quá! Thầy quá tận tình,hic,em đọc nhiều câu thắc mắc mà em cũng muốn điên đầu...đã xác định tự học thì phải kiên trì,nhẫn nại, cố gắng tự mình tìm hiểu, đọc kĩ,xem kĩ, lần lục khắp mọi nơi,đến khi bế tắc thì hẵng nhờ giúp đỡ,mới lao vào,chưa tìm hiểu gì đã hỏi,hic...em cũng từ 1 đứa chưa biết gì mò mẫm tự học,em thật ko đủ nhẫn nại để trả lời những câu hỏi như thế thầy ạ...em chúc thầy luôn khỏe ạ! |
|  | | dotantai.arch
Tổng số bài gửi : 5 Points : 9 Reputation : 0 Join date : 28/09/2012
 | Tiêu đề: Re: Các videos hướng dẫn tạo hình khối Mass 28/9/2012, 10:13 | |
| Cám ơn thầy, bài viết rất hữu ích với em  |
|  | | Sponsored content
 | Tiêu đề: Re: Các videos hướng dẫn tạo hình khối Mass  | |
Trang 1 trong tổng số 1 trang |
Similar topics |  |
| 1000> Thống Kê | Hiện có 13 người đang truy cập Diễn Đàn, gồm: 0 Thành viên, 0 Thành viên ẩn danh và 13 Khách viếng thăm :: 1 Bot Không Số người truy cập cùng lúc nhiều nhất là 162 người, vào ngày 3/8/2017, 13:30 |
Statistics | Diễn Đàn hiện có 10485 thành viên Chúng ta cùng chào mừng thành viên mới đăng ký: tranduyhungminh
Tổng số bài viết đã gửi vào diễn đàn là 3937 in 1459 subjects
Social bookmarking |
feeds | |
Khách thăm |  |
