 Curtain Wall Panel - Edit in Place
Bài gửiTiêu đề: Curtain Wall Panel - Edit in Place   22/3/2013, 13:57
You can edit a system panel in place. Yes that means you can select a curtain wall's system panel like Glass or Solid and then Edit-in-Place. Do you have a quirky design situation somewhere on your curtain wall and want to just make the change right there without creating a new panel family and loading and swapping? You can!
  • Select the panel (unpin if defined by the CW type)
  • Click Edit in Place
  • You'll find you are in Sketch Mode
  • Select and edit the solid form for glass/solid or
  • Create another form/void to design the custom panel
  • Assign Sub-category(ies)
  • Assign Material(s)
  • Finish the modelling
  • Finish the in-place editing
et Voila!
Not the right solution for multiple versions of this but when one (or a few) is all you are dealing with, not bad?!
» Ra mắt ban quản trị (Vip, Mod, SMod)
