 News in Revit 2014
Bài gửiTiêu đề: News in Revit 2014   27/3/2013, 21:58
Analysis
  • NEWBuilding element energy analysis
    Supports faster building performance analysis.
  • NEWEnhanced structural analytical model
    Analytical model enhancements provide insight.
  • NEWDuct and pipe calculations to API
    Use the API to perform pipe/duct calculations.
  • Energy Analysis for Revit
    Support sustainable design decision-making.
  • Autodesk® 360 structural analysis
    Perform static analysis from the cloud.
  • Structural analytical model
    Create/manage the structural analytical model.
  • Bidirectional links, multiple analysis packages
    Analysis results automatically update your model.
  • Physical materials for performance analysis
    Improve BIM-based building performance workflows.
Design
  • NEWEnhanced Autodesk Exchange
    Access functionality through Autodesk Exchange.
  • NEWDockable window framework
    Dock dialogs in a single window.
  • NEWStairs and railings
    More easily model, edit, and document designs.
  • NEWAir terminal on duct
    Place air terminal devices on duct faces.
  • NEWAngle constraints
    Restrict angles for pipe, duct, and cable tray.
  • NEWCap open ends
    Cap open ends of pipe or duct content quickly.
  • NEWPlumbing template
    The Plumbing-Default template speeds design.
  • NEWRebar placement constraints customization
    Gain control over rebar placement.
  • NEWReinforcement enhancements
    Get more rebar options when modeling.
  • NEWCSV file removal project
    Embed CSV data into families.
  • NEWTemporary view templates
    Change view properties temporarily.
  • Parametric components
    The graphical system for design, form making.
  • Bidirectional associativity
    A change anywhere is a change everywhere.
  • Conceptual design tools
    Sketch freely, and create free-form models.
  • NEWPoint cloud improvements
    Improve appearance and controls of point clouds.
  • NEWParameter variance for groups
    Vary the value of parameters assigned to groups.
  • HVAC/electrical design room color-fill plans
    Communicate design intent, visually.
  • Piping and electrical content
    Access electrical content within Revit. (video: 0:53 sec.)
  • Enhanced MEP systems
    Create and name duct and piping system types.
  • System browser
    Focus on the systems that are important to you.
  • Sloped piping
    Tools support enhanced productivity for piping design.
  • Multiple materials modeling
    Model your structure using the materials you need.
  • Structural reinforcement
    Define and visualize concrete reinforcement.
  • Point Cloud tools
    Connect laser scans directly into the BIM process.
  • NEWEnhanced API
    Revit 2014 includes multiple API enhancements.
Documentation
  • NEWNon-rectangular crop regions
    Crop non-rectangular model areas faster.
  • NEWSplit elevations
    Easily manage elevation cut-line configuration.
  • NEWAlternate dimensions
    Automatically display dimension values.
  • NEWImproved rebar tagging
    Annotate multiple elements with a single tag.
  • NEWImproved positioning of beams and braces
    Define geometry and position for beams and braces.
  • NEWEnhanced schedules
    Get greater control of schedule formatting.
  • Construction modeling
    Derive construction insight from design models.
  • Interoperability
    Work efficiently with your extended project team.
  • Material Takeoff
    Calculate/track detailed material quantities.
  • DWG, DWF, DXF, and DGN support
    Work with data from clients or contractors.
  • Tag on placement/by category
    Tag components as they are being placed.
  • Interface to external databases
    Output data to any ODBC-compliant database.
  • Panel schedules
    Display totals in current or load values.
  • Structural details
    Create details from views of a 3D model.
Collaboration
  • Interference check
    Scan Revit model for collisions between elements.
  • Worksharing
    Multiple users save their work to a central file.
  • Revit Server
    Collaborate on shared models across a WAN.
  • Vault integration
    Integration helps streamline data management.
  • Citrix Ready™ and 64-bit support
    Work from remote locations using a local server.
  • Autodesk® 360 integration
    Gain access to integrated Autodesk 360 features.
Visualization
  • NEWDisplaced views
    Create displaced building design views.
  • NEWEnhanced visualization
    Improve performance for visualization.
  • Design visualization
    Capture design ideas in a photorealistic state.
  • NEWRendering
    Reduce project costs with cloud-based rendering.
Bài gửiTiêu đề: Re: News in Revit 2014   1/4/2013, 21:45
Có gì mới trong Revit 2014?
Trong Revit 2014 có những chức năng cải tiến đáng kể, chúng ta hãy cùng nhau khám phá những điều mới mẻ trong Revit 2014
Displaced Views
Displaced views là một tính năng mới cho phép chúng ta exploded mô hình ra và di chuyển các thành phần một cách tự do, điều thông minh là chúng chỉ thực hiện ở trong view nhìn mà chúng ta sử dụng exploded và không ảnh hưởng đến toàn bộ mô hình.
Tính năng này chỉ hoạt động trong view nhìn 3D và phối cảnh, cho phép bạn tạo ra một view nhìn lắp ráp các bộ phận khi xây dựng. Chúng ta có thể dễ dàng thực hiện bằng cách vào view 3D, chọn các thành phần sau đó chọn tính năng displacement từ tab modify > create, chúng ta có thể di dời các thành phần một cách dễ dàng, chúng ta cũng có nút thiết lập để quay lại lúc ban đầu.
Các tính năng đường dẫn cho phép bạn tự động vẽ một đường thẳng từ vị trí ban đầu của các thành phần đến vị trí di dời của nó. Bạn có thể kiểm soát linestyle của dòng này từ Style.
Dockable Windows Framework & Enhancements
Trong những phiên bản Revit trước, các bảng tùy chỉnh Properties và Project Browser được hiển thị gồm 2 bảng riêng biệt, điều này làm cho màn hình làm việc của chúng ta đôi khi có cảm giác hơi chật hẹp, ở phiên bản Revit 2014, chúng được tích hợp lại chỉ trong một bảng điều chỉnh, chúng ta có thể di chuyển qua lại bằng các tab ở trong bảng hiệu chỉnh.
Materials
Sau thất bại với giao diện Materials ở phiên bản Revit 2013, với giao diện Materials được xem là khá phức tạp với 2 bảng tùy chỉnh, làm cho người dùng cảm thấy khó chịu, thì ở phiên bản Revit 2014 này, hãng Autodesk đã quyết định quay trở lại giống với giao diện ở những phiên bản trước, với việc sáp nhập lại trình duyệt vật liệu và chỉnh sửa vào một hộp thoại duy nhất, mọi thứ điều rõ ràng trong một hộp thoại được bố trí theo thẻ. Điều này giúp cho giao diện trở nên thân thiện hơn.
Non Rectangular Viewports
Trong tính năng này chúng ta có thể tùy chỉnh được biên dạng của crop regions và callouts, chúng sẽ không còn là một hình chữ nhật mặc định như những phiên bản trước, người sử dụng có thể tùy chỉnh hình dạng của crop regions bằng cách sử dụng các công cụ phác thảo.
Chọn crop region, sau đó chọn công cụ Edit Crop từ ribbon phác thảo. Nhưng một điều đáng tiếc là bạn vẫn chỉ được giới hạn đối với các hình dạng hình chữ nhật, không có đường cong hay là vòng cung. Tính năng này sẽ làm việc trên bất kỳ crop region nào bao gồm mặt bằng, mặt bằng trần, mặt đứng, mặt cắt, chi tiết …
Room Calculation Point
Tính năng này cho phép chúng ta đặt một cái điểm tính toán của phòng lên các loại family, với điểm tính toán này nó có thể cho chúng ta biết family của ta đang nằm ở đâu trong mô hình, từ đó chúng ta sẽ có những bản thống kê chính xác vị trí của những family này.
Double Click to Edit
Chúng ta có thể kích đúp chuột vào các thành phần sau để chỉnh sửa trực tiếp trong phiên bản Revit 2014
Element typeDouble-click behaviour
AssembliesEdit assembly mode
Schedules on SheetsOpen schedule view
Views on sheetsActivate view
Wall(EditProfile)Edit profile
Floor(EditBoundary)Edit boundary
Ceilings(EditBoundary)Edit boundary
Roof (Footprint)Edit boundary
Roof (Extrusion)Edit boundary
Slab (Edit Boundary)Edit boundary
Beam System (Edit Boundary)Edit boundary
RailingEdit railing
StairsEdit stairs
Edit Extrusion (Form)Edit form
Edit Revolve (Form)Edit form
Edit Sweep (Form)Edit form
Edit Swept Blend (Form)Edit form
Edit Blend (Default to edit Base)Edit base
Truss (Edit Profile)Edit profile
RebarEdit rebar
ReinforcementEdit rebar
Opening CutEdit sketch
Filled RegionEdit sketch
Revision CloudEdit sketch
Split Face elementEdit sketch
Người sử dụng cũng có thể tùy chỉnh các thiết lập nhấp kích đúp trong Option > User Interface
Theo http://huytraining.wordpress.com
News in Revit 2014
» Office 2010 bản mới nhất 2014
» [Share] Key bản quyền KAV - KIS 2012, 2013, 2014 update thường xuyên
» Ghi đĩa CD/DVD với Nero Burning ROM 2014 Full vĩnh viễn
» Ai sài Kaspersky Internet security 2014 xin mời vào lấy key
» Tải game CF offline 2014 CS LC 3.7
