 Kết nối BTCT trong Revit Structure 2014
Kết nối BTCT trong Revit Structure 2014 Empty
Bài gửiTiêu đề: Kết nối BTCT trong Revit Structure 2014   Kết nối BTCT trong Revit Structure 2014 I_icon_minitime28/3/2013, 11:11
Bài gửiTiêu đề: Re: Kết nối BTCT trong Revit Structure 2014   Kết nối BTCT trong Revit Structure 2014 I_icon_minitime31/3/2013, 14:08
I always found it very annoying when the slab took priority over the columns, the main reason was that when you produce a graphical column schedule the columns appeared broken at each floor! You can now finally choose your intended join order.
Kết nối BTCT trong Revit Structure 2014 Join-order-icon
Below are two images showing the two possible results based on the Switched Join Order.
Kết nối BTCT trong Revit Structure 2014 Join-order-1Kết nối BTCT trong Revit Structure 2014 Join-order-2Kết nối BTCT trong Revit Structure 2014 Graphical-column-schedule
You can now also see that the graphical column schedule is displaying correctly, of course, this was only an issue with concrete members.
» Copy cột từ bản liên kết Revit Architecture trong Revit Structure 2011
» Revit Structure 2014 - Analytical Nodes
» Revit Structure 2014 Tutorial – Analytical nodes
» Revit Structure 2014 – Concrete Join Order
» Revit Structure 2014 Beams & Braces – Geometric Positions
