 Revit 2014 Properties Palette Tabs
Bài gửiTiêu đề: Revit 2014 Properties Palette Tabs   31/3/2013, 14:10
If you use Revit MEP you know how little screen space you can end up with if you open up the Properties Palette, Project Browser, System Browser and Reconcile Hosting dialogs at the same time. You can shrink them down pretty small but then they don't function very well. Sure you can close and open them as needed or put them on a second monitor too.
Revit 2014 offers another option, nest them on the Properties Palette and provide tabs for each so you can switch back and forth.
Jury is still out on this for me. I set it up and used it this way for quite awhile but kept forgetting where and which tab was active. One recurring comment was to have the focus or active tab switch to properties when elements are selected but I'm not sure if that worked its way into the final production release.
It is a little tricky at first to get them hosted on the palette, easy once you know how. Just click on the dialog title bar, drag it either to the title bar on the Properties Palette or over the tab(s) at the bottom of the palette. Either way you'll get a ghost of the overlay and a new tab will appear. Don't let go if you don't see the new tab appear, means it isn't going to work.
Love the subtle stuff!
» Office 2010 bản mới nhất 2014
» [Share] Key bản quyền KAV - KIS 2012, 2013, 2014 update thường xuyên
» Ghi đĩa CD/DVD với Nero Burning ROM 2014 Full vĩnh viễn
» Ai sài Kaspersky Internet security 2014 xin mời vào lấy key
» Tải game CF offline 2014 CS LC 3.7
