 cấu hình máy tính và hệ điều hành chạy Revit 2014
Bài gửiTiêu đề: cấu hình máy tính và hệ điều hành chạy Revit 2014   1/4/2013, 22:27
Autodesk Revit 2014 Product System Requirements
For Autodesk® Revit® 2014, Autodesk® Revit® Architecture 2014, Autodesk® Revit® MEP 2014, and Autodesk® Revit® Structure 2014
Minimum entry-level configuration
•Windows® 7 32-bit Enterprise, Ultimate, Professional, or Home Premium edition operating system[1]
•Single- or multi-core Intel® Pentium®, Intel® Xeon®, or i-Series processor or AMD equivalent with SSE2 technology (highest affordable CPU speed rating recommended)
•Multiple cores for many tasks, up to 16 cores for near-photorealistic rendering operations
•4 GB RAM (Usually sufficient for a typical editing session for a single model up to approximately 100 MB on disk. This estimate is based on internal testing and customer reports. Individual models will vary in their use of computer resources and performance characteristics.)
•Models created in previous versions of Revit products may require more available memory for the one-time upgrade process
•/3GB RAM switch not recommended. Revit software and system stability can be affected by memory conflicts with video drivers when the /3GB switch is active.
•5 GB free disk space
•1,280 x 1,024 monitor with true color
•Display adapter capable of 24-bit color for basic graphics, 256 MB DirectX® 11-capable graphics card with Shader Model 3 as recommended by Autodesk
•Microsoft® Internet Explorer® 7 (or later)
•MS-Mouse or 3Dconnexion®-compliant device
•Download or installation from DVD9 or USB key
•Internet connectivity for license registration and prerequisite component download
Value: Balanced performance
•Windows® 8 64-bit Enterprise or Professional edition, or Windows 7 64-bit Enterprise, Ultimate, Professional, or Home Premium edition operating system
•Multicore Xeon or i-Series processor or AMD equivalent with SSE2 technology (highest affordable CPU speed rating recommended)
•8 GB RAM (Usually sufficient for a typical editing session for a single model up to approximately 300 MB on disk. This estimate is based on internal testing and customer reports. Individual models will vary in their use of computer resources and performance characteristics.)
•Models created in previous versions of Revit software products may require more available memory for the one-time upgrade process
•1,680 x 1,050 monitor with true color
•DirectX 11 capable graphics card with Shader Model 3 asrecommended by Autodesk
•Internet Explorer 7 (or later)
•MS-Mouse or 3Dconnexion-compliant device
Performance: Large, complex models
•Windows 8 64-bit Enterprise or Professional edition, or Windows 7 64-bit Enterprise, Ultimate, Professional, or Home Premium edition
•16 GB RAM (Usually sufficient for a typical editing session for a single model up to approximately 700 MB on disk. This estimate is based on internal testing and customer reports. Individual models will vary in their use of computer resources and performance characteristics.)
•5 GB free disk space; 10,000+ RPM for Point Cloud interactions
•1,920 x 1,200 monitor with true color
•DirectX 10 capable graphics card with Shader Model 3 asrecommended by Autodesk
» miễn phí một năm sử dụng AVG Internet Security 2011 trị giá 44.99$
» Hình vài con parabol còi của em
» Kết hợp tivi hổ trợ công nghệ dvb-t2 và đầu thu + chảo vinasat để xem các kênh 2 đầu thu
» Giúp em chỉnh chảo K+ ở Thái Lan, Chiang Mai
» Paltalk cho người nghèo.
