 Revit Structure 2014 Beams & Braces – Geometric Positions
Revit Structure 2014 Beams & Braces – Geometric Positions Empty
Bài gửiTiêu đề: Revit Structure 2014 Beams & Braces – Geometric Positions   Revit Structure 2014 Beams & Braces – Geometric Positions I_icon_minitime27/4/2013, 19:26
Posted on April 3, 2013 by lawrenceh
In a previous post I outlined a procedure and method of offsetting beams both in the horizontal and vertical planes whilst leaving the analytical model unaffected. In the new Revit 2014 release Autodesk have included some interesting new tools to control these offsets more effectively. Of particular interest is the new behavior of roof bracing.
Revit Structure 2014 Beams & Braces – Geometric Positions 2013-2014-properties
In Revit 2014 these new tools are grouped under the Geometric Position section on the properties ribbon. You can see that these positions relate to the Y and Z axis. To understand this, refer to the image showing the plan view of a beam.
Revit Structure 2014 Beams & Braces – Geometric Positions Beam-plan-view
The key thing to remember is that the Y axis is the offset in plan and the Z is the offset in the vertical direction.
The offsets can either be uniform or independent. For most examples you will likely want to keep a uniform offset but I have found that the independent offset is really useful for offsetting bracing on roof members of differing depths. Notice the below image and the offset of 76mm on the end offset value to maintain a horizontal position for the CHS bracing. At last, a workable solution!
Revit Structure 2014 Beams & Braces – Geometric Positions Bracing-offset
Anyway, have a play with these new tools, I am sure they will help you all.
LawrenceH
Source: http://revitstructureblog.wordpress.com/2013/04/03/revit-structure-2014-beams-braces-geometric-positions/
» Revit Structure 2014 - Analytical Nodes
» Kết nối BTCT trong Revit Structure 2014
» Revit Structure 2014 Tutorial – Analytical nodes
» Revit Structure 2014 – Concrete Join Order
» Mô hình Revit structure 2014 chuyển qua Robot Structural Analysis
