 Cách tạo hốc thủng hình dạng bất kỳ trên tường cong
Bài gửiTiêu đề: Cách tạo hốc thủng hình dạng bất kỳ trên tường cong   24/6/2013, 23:10
When you need to alter the rectangular shape of a wall, use the Edit Profile tool.  When editing the profile of a wall, sketch mode is enabled and you can alter the shape or make openings in the rectangular shape of the default wall.  The Edit Profile tool only works on straight wall segments.  If the wall is curved in a plan view, the Edit Profile button is inactive and can’t be selected.
If you need to make a rectangular opening in a curved wall, use the Wall Opening tool.  This tool allows you to select a wall and then use 2 clicks to create a rectangular opening.  After the opening is placed, use the shape handles to alter the size and position of the opening.
If you need to make a non-rectangular shape or opening in a curved wall, use an in-place family void to cut the shape out of the wall.
  • Click the Model In-Place tool (from the Component drop-down).
  • Assign the component to the Generic Models category as it is only being used to modify the geometry of the wall.
  • Enter a descriptive name.
  • Use the void forms to model the opening needed in the wall.
    Make sure the voids intersect the wall you wish to cut.
  • Use the Cut Geometry tool to cut the void geometry from the wall geometry, and then Finish the in-place model.
Source:
http://wikihelp.autodesk.com/Revit/enu/Community/Tips_and_Tricks/Modeling/Create_an_Opening_in_a_Curved_Wall
» Tin HOt! AVG...phát sóng tại Việt Nam trên NSS6
» Đầu thu hl bị mất màu
» Xin tài liệu về kết nối PC với K49
» Lấy camera mobile làm dụng cụ thử khi sửa remote.
» Vẫn đề thiết kế quạt cho f8 và s18
Thiết kế 3D :: CHUYÊN NGÀNH REVIT :: AUTODESK REVIT THEO CHUYÊN ĐỀ :: Thủ thuật trong Revit-
