 Creating a Solid Railing
Creating a Solid Railing Empty
Bài gửiTiêu đề: Creating a Solid Railing   Creating a Solid Railing I_icon_minitime24/6/2013, 23:13
Thanks to Autodesk's Ping Jiang for contributing this advanced tip for Revit 2013.
A quick way to create a solid panel railing is to modify the type properties for the top rail profile family used in the railing system so that the profile height dimension is the same as the top rail height.
In the following example, the Rectangular Handrail type is used for the top rail in the railing system, and in the railing type properties, the top rail Height is set to 3'. To create the solid railing, locate the profile family for the Rectangular Handrail in the Project Browser, and open the type properties.Change the Height value under Dimensions to 3'.
Creating a Solid Railing =railing_tp_solid1
The best transition method for the top rail in this configuration is Simple. Open the type properties for the top rail (Use Tab in the drawing area to highlight the top rail instead of the railing system), and under Construction, for Transitions, select Simple.
Creating a Solid Railing =railing_tp_solid2
You should see a railing similar to the following:
Creating a Solid Railing =railing_tp_solid3
Note: For projects where the solid railing does not connect smoothly (known issue), delete the automatic railing and create separate railings for each segment using the Railing by Sketch tool. This way you can also apply different railing types to the runs and landings to adjust the height of the railing as needed.
Source: http://wikihelp.autodesk.com/Revit/enu/Community/Tips_and_Tricks/Modeling/Creating_a_Solid_Railing
» Creating a sweep that wraps around the wall end
» Creating Title Block From AutoCAD Sheet
» Creating Piping Systems in REVIT Part 1
» Creating Piping Systems in Revit Part 2
» Creating Sample Drawing from Autodesk Advance Steel
Thiết kế 3D :: CHUYÊN NGÀNH REVIT :: AUTODESK REVIT THEO CHUYÊN ĐỀ :: Thủ thuật trong Revit-
