 Creating a Solid Railing
Bài gửiTiêu đề: Creating a Solid Railing   24/6/2013, 23:13
Thanks to Autodesk's Ping Jiang for contributing this advanced tip for Revit 2013.
A quick way to create a solid panel railing is to modify the type properties for the top rail profile family used in the railing system so that the profile height dimension is the same as the top rail height.
In the following example, the Rectangular Handrail type is used for the top rail in the railing system, and in the railing type properties, the top rail Height is set to 3'. To create the solid railing, locate the profile family for the Rectangular Handrail in the Project Browser, and open the type properties.Change the Height value under Dimensions to 3'.
The best transition method for the top rail in this configuration is Simple. Open the type properties for the top rail (Use Tab in the drawing area to highlight the top rail instead of the railing system), and under Construction, for Transitions, select Simple.
You should see a railing similar to the following:
Note: For projects where the solid railing does not connect smoothly (known issue), delete the automatic railing and create separate railings for each segment using the Railing by Sketch tool. This way you can also apply different railing types to the runs and landings to adjust the height of the railing as needed.
Source: http://wikihelp.autodesk.com/Revit/enu/Community/Tips_and_Tricks/Modeling/Creating_a_Solid_Railing
Thiết kế 3D :: CHUYÊN NGÀNH REVIT :: AUTODESK REVIT THEO CHUYÊN ĐỀ :: Thủ thuật trong Revit-
