| Tiêu đề: Cấu hình máy tính để chạy Revit 2012 31/3/2011, 18:15 | |
| For 32-Bit Autodesk Revit MEP 2012
- Microsoft® Windows® 7 32-bit Enterprise, Ultimate, Professional, or Home Premium, Microsoft® Windows Vista® 32-bit (SP2 or later) Enterprise, Ultimate, Business, or Home Premium, or Microsoft® Windows® XP (SP2 or later) Professional or Home edition*
- For Microsoft Windows 7 32-bit or Microsoft Windows Vista 32-bit: Intel® Pentium® 4 or AMD Athlon™ dual-core processor, 3.0 GHz (or higher) with SSE2 technology
- For Microsoft Windows XP: Intel Pentium 4 or AMD Athlon dual core, 1.6 GHz (or higher) with SSE2 technology
- 4 GB RAM (Usually sufficient for a typical editing session for a single model of approximately 100 MB on disk)
- 5 GB free disk space
- 1,280 x 1,024 monitor with true color
- Display adapter capable of 24-bit color for basic graphics, 256 MB DirectX® 10-capable graphics card with Shader Model 3 for advanced graphics (find out more about recommended graphics hardware)
- Microsoft® Internet Explorer® 7.0 (or later)
- Microsoft Mouse-compliant pointing device
- Download or installation from DVD9
- Internet connectivity for license registration
For 64-Bit Autodesk Revit MEP 2012
- Microsoft Windows 7 64-bit Enterprise, Ultimate, Professional, or Home Premium edition, Microsoft Windows Vista 64-bit (SP2 or later) Enterprise, Ultimate, Business, or Home Premium edition, or Microsoft® Windows® XP Professional x64 edition (SP2 or later)*
- For Windows 7 64-bit or Windows Vista 64-bit: Intel® Core™ i5-2300 quad-core processor (2.8 GHz, 6 MB cache) or equivalent AMD® processor.
- For Windows XP Professional x64: Intel Pentium 4 or AMD Athlon dual core, 1.6 GHz (or higher) with SSE2 technology
- 8 GB RAM (Usually sufficient for a typical editing session for a single model of approximately 300 MB on disk)
- 1,680 x 1,050 monitor with true color
- 1 GB DirectX 10 capable graphics card with Shader Model 3 (find out more about recommended graphics hardware)
- Internet Explorer 7.0 (or later)
Performance Recommendations for Large Complex Models
- Intel® Core™ i7-2600 quad-core processor (3.8 GHz, 8 MB cache ) or equivalent AMD processor
- 16 GB RAM (or more—usually sufficient for a typical editing session for a single model of approximately 700 MB on disk)
- 1,980 x 1,200 monitor with true color
- 2 GB (or more) DirectX 10-capable graphics card with Shader Model 3 (find out more about recommended graphics hardware)
Autodesk Revit Server 2012Less than 100 Concurrent Users
- Microsoft® Windows® Server 2008 R2 64-bit, or Microsoft® Windows® Server 2008 64-bit
- Processor with 4 or more cores and at least 2.6 GHz (6 or more cores and 3 GHz for maximum performance)
- Microsoft® Internet Information Server 7.0 (or later)
- 4 GB RAM (16 GB for maximum performance)
- 7,200 or more RPM hard drive (15,000 or more RPM for maximum performance)
- VMware® Support
100 or More Concurrent Users
- Microsoft Windows Server 2008 R2 64-bit, or Microsoft Windows Server 2008 64-bit
- Microsoft Internet Information Server 7.0 (or later)
- 8 GB RAM (32 GB RAM for maximum performance)
- 10,000 or more RPM hard drive (high-speed RAID array for maximum performance)
- VMware Support
Revit MEP for Citrix** 2012 (tính năng mới)
- Microsoft Windows 7 64-bit, Microsoft Windows 7 32-bit, Microsoft Windows XP Professional x64 Edition (SP2), or Microsoft Windows XP (SP2 or later)
- Citrix system with XenApp® 6.0, Citrix® License Manager, and Citrix® Profile Manager
- Microsoft® Active Directory with support for roaming profiles
- Dedicated Autodesk license server for session-specific licenses
- Microsoft Internet Explorer 7 (or later)
- Client computers should be bound to the network domain. Each client computer should install either the full or web online client plug-in.
- Users should use their domain logins to access both the Citrix web console and the LAN. Client computers should be bound to the network domain. Each client computer should have either the full or web online client plug-in installed.
* Learn More about using Autodesk Revit MEP software with Boot Camp®, part of Mac OS® X that enables you to install and run Microsoft Windows (and Windows-based applications) on a Mac® computer or with Parallels Desktop, a system utility available from Parallels, Inc. that allows you to run applications in each operating system without restarting your computer.**Autodesk Revit MEP 2012 is a Citrix Ready™ Application. Additional Disclaimer: The Citrix application is network-based, and performance of Autodesk Citrix Ready Applications may vary with network performance. The software does not include the Citrix application, nor does Autodesk provide direct support for issues with the Citrix application. Users should contact Citrix directly with questions related to procurement and operation of the Citrix application.” Note: Autodesk tests and supports Revit releases using hardware environments similar to those summarized in this document. Alternative hardware installation environments or software package interactions may cause undesirable behaviors in an installation of Revit. While Autodesk will make a reasonable effort to reproduce customer issues brought to the attention of Product Support, it is impossible for Autodesk to reproduce every customer computing environment for testing or support purposes. | |
manhthangcec
Tổng số bài gửi : 3 Points : 3 Reputation : 0 Join date : 02/06/2013
| Tiêu đề: Re: Cấu hình máy tính để chạy Revit 2012 18/6/2013, 23:01 | |
| Thày ơi, laptop của em cấu hình thế này có chạy được revit arc 2013 không ạ: corei 3 2.2 GHz; DDR3 6 GB; HDD 500 GB; graphic card Nvidia GT 520MX | |
| Tiêu đề: Re: Cấu hình máy tính để chạy Revit 2012 18/6/2013, 23:23 | |
| Tiêu đề: Re: Cấu hình máy tính để chạy Revit 2012 | |
