 Sản phẩm Autodesk 2012
Bài gửiTiêu đề: Sản phẩm Autodesk 2012   22/4/2011, 07:35
Bản cài đặt dùng thử:
Revit Architecture 2012
Revit Structure 2012
Revit Mep 2012
Key Autodesk 2012
1. Download and install bản trial. Ngắt kết nối internet sau khi cài đặt xong.
2. Khi có yêu cầu chèn một số thứ, chèn các dãy sau:
400-45454545 hoặc 667-98989898 hoặc 666-69696969
tiếp theo là Product Key:
001D1 - Autodesk AutoCAD 2012
057D1 - AutoCAD LT 2012
128D1 - Autodesk 3ds Max 2012
129D1 - AutoCAD Map 3D 2012
185D1 - AutoCAD Architecture 2012
206D1 - AutoCAD Mechanical 2012
225D1 - Electrical 2012
235D1 - AutoCAD MEP 2012
237D1 - Civil 3D 2012
240D1 - AutoCAD Revit Architecture 2012
241D1 - AutoCAD Revit Architecture Suite 2012
255D1 - AutoCAD Revit Structure 2012
256D1 - AutoCAD Revit Structure Suite 2012
257D1 - AutoCAD Revit MEP Suite 2012
262D1 - Showcase 2012
276D1 - Autodesk MapGuide 2012
279D1 - Direct Connect for JT 2012
294D1 - Inventor Tooling Suite 2012
295D1 - Autodesk Showcase Professional 2012
297D1 - AutoCAD Revit MEP 2012
340D1 - Raster Design 2012
426D1 - AutoCAD Plant 3D 2012
448D1 - Autocad P&ID 2012
462D1 - AutoCAD Inventor Professional Suite 2012
464D1 - Inventor R-SYS 2012
466D1 - Inventor SIMULATION 2012
467D1 - Autodesk Topobase Web 2012
475D1 - Topobase Client 2012
495D1 - Autodesk 3ds Max Design 2012
504D1 - Navisworks Review 2012
506D1 - Navisworks Simulate 2012
507D1 - Navisworks Manage 2012
527D1 - Inventor Suite 2012
532D1 - Direct Connect for CATIA 4
544D1 - CIVIL 2012
546D1 - Robot Structural Analysis 2012
547D1 - Robot Structural Analysis Pro 2012
569D1 - Autodesk Vault Manufacturing 2012
586D1 - Showcase Presenter 2012
587D1 - AutoCAD Structural Detailing 2012
589D1 - Autodesk Revit MEP-C 2012
590D1 - Autodesk Softimage 2012
592D1 - AutoCAD Visual Suite XGD 2012
595D1 - AutoCAD Revit Architecture Visualization Suite 2012
596D1 - AutoCAD Inventor LT 2012
597D1 - Navisworks Manufacturing Manage 2012
598D1 - Navisworks Manufacturing Review 2012
599D1 - Navisworks Manufacturing Simulator 2012
657D1 - Autodesk Maya 2012
666D1 - Autodesk Inventor Publisher 2012
667D1 - Autodesk Algor Simulation Pro 2012
710D1 - ALIAS AUTOMOTIVE 2012
712D1 - ALIAS DESIGN 2012
714D1 - Direct Connect for Catia 5
719D1 - Direct Connect for NX 2012
732D1 - Sketchbook Pro 2012
736D1 - ALIAS SURFACE 2012
772D1 - Autodesk Frestyle 2012
3. Nhấn Next. Vài thông báo rằng the code có thể đúng hoặc sai, bỏ qua điều đó(some message
4. Nhấn OK hoặc exit.
5. Nhấn Next lại.
6. Install product. Đừng quên xây dựng cấu hình mà bạn muốn trong AutocAD!!!
7. Finish installation và exit. Khởi động lại máy sau khi cài đặt xong
8. Khởi động AutoCAD.
9. Chọn the Activate option.
10. Chọn Run As Administrator bản keygen "xf-adesk2012-32bits" hoặc "xf-adesk2012-64bits".
11. Nhấn Mem Patch. Dòng "Succeed" sẽ xuất hiện và nhấn ok.
12. Copy the request code từ AutoCAD vào Keygen.
13. Nhấn Generate.
14. Copy Keygen activation code đó là generated.
15. Trong AutoCAD, chọn Activate now hoặc chèn Serial hoặc thứ gì đó tương tự.
16. Dán Activation Code.
17. Nhấn Next.
Bây giờ bạn đã có bản full version of Autodesk AutoCAD 2012 và nó đã được đăng ký
Kết nối internet trở lại.
Chúc thành công.
Link keygenerator:
mediafire.com ?twu15dxv7ugd06o
hahahugo
Bài gửiTiêu đề: Re: Sản phẩm Autodesk 2012   25/5/2011, 21:44
thật là tốt quá, đúng là thứ mình cần
mà nhân tiện cho cháu hỏi bác có tài liệu gì về inventor pro 2012 ko ạ
» Sẽ không còn kênh Star Movies ở hầu hết châu Á từ ngày 1/1/2012
» ALBUM ẢNH " XUÂN NHÂM THÌN" 2012 !
» ProrShow Gold 5 +key+crack (bãng mới nhất 3/2012
» Tin mới : True - UBC đã chính thức nâng cấp hệ thống lúc 23h 15/07/2012
» Mời offline hè 2012 DVB miền Bắc mang tên: Chia sẻ đam mê - kết nối bằng hữu
Thiết kế 3D :: THÔNG TIN TỔNG HỢP-
