 Revit and Brick Coursing
Bài gửiTiêu đề: Revit and Brick Coursing   22/6/2011, 08:19
Wednesday, 29 April 2009 11:28
Revit and Modular Coursing (Brick/Block Coursing)
There are a number of tools in Revit that help you achieve Brick/Block Coursing, or for that matter any modular coursing of elements. The best approach to coursing is to set your building out crudely at first for initial design, then work up accurate coursing later on.
There are several ways to draw in Revit to approximate coursing:
[url=http://www.revitstore.com/index.php?option=com_content&view=article&id=104:revit-and-brick-coursing&catid=37:tips-and-tricks&Itemid=55#Procedure 1]Procedure 1[/url]: Using the Align tool to achieve approximate coursing, or
[url=http://www.revitstore.com/index.php?option=com_content&view=article&id=104:revit-and-brick-coursing&catid=37:tips-and-tricks&Itemid=55#Procedure 2]Procedure 2[/url]: Setting a visible Workplane and specifying a module spacing.
In addition to this, you can get Revit to course accurately:
[url=http://www.revitstore.com/index.php?option=com_content&view=article&id=104:revit-and-brick-coursing&catid=37:tips-and-tricks&Itemid=55#Procedure 3]Procedure 3[/url]: Using the Line Based Coursing Detail Component tool.
Procedure 1: Using the Align tool to achieve approximate coursing
In most early stage design, coursing is not necessary, however in the case of coursing brickwork in elevation it is sometimes necessary to place Windows and Doors approximately in line with vertical joins and to ensure that vertical perp-ends line through on corners.
There are two types of Fill Patterns in Revit, Surface and Cut; only Surface patterns may be moved/rotated.
Procedure (Aligning Elevation Surface patterns):
  • Open an Elevation View and zoom into the corner of the Building.
  • Using the Align tool, select the corner of the Building first followed by any of the vertical lines within the walls surface pattern.
  • Next, using the Align tool again. Click on the Vertical line in the surface pattern you wish to align the Windows/Doors with, followed by the edge of the Window/Door.
    The finished result:
Procedure 2: Setting a visible Workplane and specifying a module spacing.
As an early stage design aid, you can set and use the Workplane tool to draw and snap objects against. This could be useful as a planning grid guide, but note that it will not plot/print.
Procedure (Using the Workplane tool):
  • Turn the Workplane visibility on, by clicking ....
    2009 Interface: The Workplane Visibility button on the ‘Tools’ toolbar.
    2010 Interface: Click the Show Workplane button on the ‘Workplane’ Panel on the Home Ribbon.
  • Now select the workplane that has appeared and on the Options Bar you can change the spacing of the grid. You may resize the Grid by selecting a control on each edge and drag it in or out to resize. You can even move the grid accurately to a chosen location.
  • You may now draw elements that snap to this grid. So by setting the spacing to 225mm you would be able to draw a wall at brick co-ordinating lengths.
    Note in the next procedure we examine how to achieve accurate Masonry coursing CO, CO+,CO-.
Procedure 3: Using the Line Based Coursing Detail Component tool.
There are two ‘Line Based Detail Component Families’ in the UK library, one is for coursing in Section and the other for coursing in Plan views.
They are both located in the ‘Detail Components’ section of the Metric Library, under a folder called ‘Annotations’ and named - Coursing Lines in Plan.rfa and Coursing Lines in Section-Elevation.rfa.
Procedure (Using the Detail Components for coursing)
  • Load from Library either of the two Families listed above.
  • Open a plan or a section view that requires coursing.
  • Pick the Detail Component tool
    2009 Interface – Drafting Tab of the Design Bar.
    2010 Interface – Annotate Ribbon, Detail Panel.
  • Draw between two points, with the first point positioned on the corner of a wall, in the case of the image below; or where you wish the coursing to start from in a section view.
  • It may be easiest to use the thin lineweights tool, so that you can see all coursing lines in the Line Based Detail Component.
  • Zoom in, and you can now use the Align tool to select the coursing line that you wish to align your Windows/Doors in Plan and it could be your repeating details in section views. Note if you are trying to align Repeating Details, you can only align the ends of the Repeating Details not any of the individual components within it.
  • Finally delete the Detail Component and create a new one to continue coursing accurately in another location.
    Note: Also it may be beneficial if you amend the current dimension type units to display to 1 decimal place and Suppress trailing 0’s in the case of Brickwork coursing where you require your dimensions to the nearest 0.5mm.
    Written By: Ian Howard revitstor.com
