 Ghi kích thước trong revit
3 posters
Ghi kích thước trong revit Empty
Bài gửiTiêu đề: Ghi kích thước trong revit   Ghi kích thước trong revit I_icon_minitime8/12/2010, 21:32
Dimensions: An introduction
Ghi kích thước trong revit Trans Ghi kích thước trong revit Pdf_buttonGhi kích thước trong revit PrintButtonGhi kích thước trong revit EmailButton
Welcome to this Revit Zone article on Dimension types. In this article we are going to take a look at all the various types of dimensions that are available to you within Revit. For each dimension type, we will describe it’s type and take a look at an example of it in use.
In a separate article we will take a look at how you can customise the look of your dimensions (overriding the automatic values, for example). Please also note that this article focuses on permanent dimensions- as opposed to temporary dimensions, which will be discussed in a separate article.
The dimension tools available to you can be found on the “Annotate” menu, in the “Dimension” tab…..
Ghi kích thước trong revit Dimensions_01
Aligned dimensions
The first dimension type that we are going to look at are Aligned Dimensions. The key thing to note about Aligned Dimensions are that they can be placed between 2 or more parallel references or 2 or more points- wall ends for example. The dimensions in the image below are all Aligned Dimensions….
Ghi kích thước trong revit Dimensions_02
One important thing to note here is that when you select “Aligned” to start dimensioning, the Options bar presents you with some important choices that will aid you in creating your dimensions….
Ghi kích thước trong revit Dimensions_03
You will see above that you have a choice as to what Revit snaps to when dimensioning. The “Place Dimension” drop down box contains Wall centrelines, Wall faces, Centre of core and Faces of core. The second choice you have when placing your dimensions are “Pick”….
Ghi kích thước trong revit Dimensions_04
At this point it is worth taking a moment to look at the differences between these two options because this is something that you will use time and again.
If we leave “Pick” set at “Individual References”, you have the choice where to dimension to, along a wall length- ie from the end of the wall to the start of the first window opening….
Ghi kích thước trong revit Dimensions_05
However, if you change “Pick” to “Entire Walls”, you can now just pick anywhere on the wall and the entire wall is automatically dimensioned….
Ghi kích thước trong revit Dimensions_06
Note that all the dimensions were added in one go, following a single click on the wall. To tell Revit exactly what elements of the wall you wish to be dimensioned, click on “Options” on the Options Bar (this is only available if you have “Pick” set to “Entire Walls”….
Ghi kích thước trong revit Dimensions_07
You will see that you can dimension (automatically) to openings, intersecting wall and intersecting grid lines. Used appropriately, this feature can save you a vast amount of time. Imagine a long elevation with 14 windows and 3 doors- and being able to dimension all of it with a single click! Ok, that’s enough of Aligned Dimensions, let’s move on.
Linear dimensions
Next on our list are “Linear Dimensions”. We use Linear Dimensions, when we want the absolute distance (measured vertically or horizontally) between two offset points. This is better explained with a diagram….
Ghi kích thước trong revit Dimensions_08
Angular dimensions
As you may expect, Angular Dimensions are used to measure the angle between two reference points that share a common intersection. Quite simply click on the first reference element (be it a line, wall, etc) and then on the second one….
Ghi kích thước trong revit Dimensions_09
Radial dimensions
Radial dimensions are used for measuring the distance from an arc to it’s centre point. In the case of Walls, you can measure either to the wall centreline or the wall face. Pressing the “tab” key when defining your dimension will toggle between wall face and wall centreline….
Ghi kích thước trong revit Dimensions_10
Arc Length dimensions
Radial dimensions are used for measuring the distance along an arc segment. This could be a line or wall. Again the “Tab” key will toggle between centrelines and faces, in the case of walls.
Ghi kích thước trong revit Dimensions_11
Baseline and Ordinate dimensions
Two other linear dimension types that are available to you (but not obviously evident) are “Baseline” and Ordinate” dimensions. These are basically two different types of “Running Dimensions”. In order top use these, you will need to first create the dimension types. This is really easy to do- just pick the default Linear (or Aligned) dimension family and duplicate it (renaming it of course). Once you have a copy of the family, you can go into it’s properties and “Edit Type”…..
Ghi kích thước trong revit Dimensions_12
You will notice that the first parameter in the list is “Dimension String Type”. This is the parameter we are interested in. If you activate the drop-down menu for this parameter- you will see that you have a choice of “Continuous”, “Baseline” or “Ordinate”. Go ahead and change the parameter to “Baseline”. This results in a dimension like this….
Ghi kích thước trong revit Dimensions_13
And if then produce a second dimension family with the “Dimension String Type” set to “Ordinate”, this is what you get….
Ghi kích thước trong revit Dimensions_14
On the face of it this looks just like a standard aligned / linear dimension. But if you look closely you will see that each dimension value is measured back to the base point of 0.
Spot Dimensions.
There are 3 types of Sot Dimensions: Spot Elevations, Spot Coordinates and Spot Slopes…
Ghi kích thước trong revit Dimensions_15
Spot Elevation dimensions
Spot Elevations are used in elevation, section, plan and 3D views to display the absolute (or relative) heights of reference points. They can also display the upper and lower height values of an element with thickness (eg a floor), in plan views.
Here is a Spot Elevation in a section view, telling us the height at the top of the wall……
Ghi kích thước trong revit Dimensions_16
And here is a Spot Elevation in a plan view. This time it is displaying the bottom and top heights of a floor plate element…..
Ghi kích thước trong revit Dimensions_17
Spot Coordinates dimensions
Spot Coodinates display the North / South and East / West coordinates of the reference point it is placed at. It can also display the elevation at that height too….
Ghi kích thước trong revit Dimensions_18
Spot Slope dimensions
And finally…….. Spot Slope Dimensions! As you might well expect, these are used for displaying the angle of slope on various surfaces and elements. They can be placed in section, elevation and plan views. Here is one being used on a roof slope in a section view…..
Ghi kích thước trong revit Dimensions_19
You have a choice of an arrow or a triangle for the symbol- we have obviously chosen the triangle symbol in the above example.
And that concludes our introductory look at Dimensions in Revit. In other articles we will go onto to look at how we can manipulate and customise the look and operation of these various dimension types.
Source: revitzone.com
tinhlagi
Bài gửiTiêu đề: Re: Ghi kích thước trong revit   Ghi kích thước trong revit I_icon_minitime18/12/2010, 00:37
Cám ơn Thầy ạh! Em chưa học đến phần này Razz
Kientrucsongcau
Tổng số bài gửi : 15
Bài gửiTiêu đề: Re: Ghi kích thước trong revit   Ghi kích thước trong revit I_icon_minitime22/4/2012, 15:18
Xin hỏi diễn đàn về vấn đề ghi kích thước trong revit.
Mình muốn ghi kích thước nhanh (Quick dimension) như cad thì phải làm thế nào, mình vẫn chưa thấy linh hoạt trong khi dim ở revit so với cad.
cám ơn diễn đàn.
» Các loại kích thước trong Revit
» Giup ghi kich thuoc trong revit
» Thủ thuật khi thay đổi kích thước trong Revit
» Ghi kích thước tại khung nhìn 3D trong Revit
» Thắc mắc về vấn đề vẽ cầu thang với các bậc kích thước khác nhau trong Revit
Thiết kế 3D :: CHUYÊN NGÀNH REVIT :: AUTODESK REVIT THEO CHUYÊN ĐỀ :: Hồ sơ thiết kế-
