 Installing RPC - ArchVision Content Manager
Installing RPC - ArchVision Content Manager Empty
Bài gửiTiêu đề: Installing RPC - ArchVision Content Manager   Installing RPC - ArchVision Content Manager I_icon_minitime3/4/2012, 09:57
This Tutorial - Installing RPC - ArchVision Content Manager will guide you through the steps of installing the ArchVision Content Manager necessary to place RPC objects in your SketchUp model and render them.
Contents
Step 1 - Download RPC Content Manager
Installing RPC - ArchVision Content Manager Acm-0
If you click the RPC icon ( Installing RPC - ArchVision Content Manager Rpc24 ) in IRender nXt toolbar and if the RPC content manager is not loaded yet, this dialog will appear.
(If the content manager is already installed, the icon will jump to Step 4 below.)
You can also jump directly to the ArchVision Content Manager download here: ArchVision Content Manager
Follow this process to download the ArchVision Content Manager:
Installing RPC - ArchVision Content Manager Acm2
Click Install a Free ACM to continue.
You may get a message like this:
Installing RPC - ArchVision Content Manager Acm3
If so, Click 'Save File or Open.
Step 2 - ArchVision Content Manager Installation
Click Next for each step of the installation:
Installing RPC - ArchVision Content Manager Acm4
Installing RPC - ArchVision Content Manager Acm5
Installing RPC - ArchVision Content Manager Acm6
Installing RPC - ArchVision Content Manager Acm7
Step 3 - Configuring the Content Manager
After installation, the ArchVision Content Manager Configuration Dialog may appear automatically, or you may need to run it from the Program Manager, or you may launch it the next time you click the RPC icon in IRender nXt.
Installing RPC - ArchVision Content Manager Acm9
Select a default location for your RPC files. and click Configure
Click Ok on the next dialog box.
Installing RPC - ArchVision Content Manager Acm10
If this dialog appears, Click the X in the upper right corner to take it down.
Installing RPC - ArchVision Content Manager Acm11
Step 4 - Select and Place an RPC Object
Installing RPC - ArchVision Content Manager Acm12
The next time you click the RPC icon in SketchUp, this dialog should appear.
Select a .RPC file and click Ok.
Installing RPC - ArchVision Content Manager Acm13
This dialog should appear to let you place the component generated from the RPC file into SketchUp.
See: RPC for more information on using RPC Content.
Source: renderplus.com
» Cài Revit 2015 bị lỗi Content Libraries
» Thư viện 3D Content Collection Free
» US Metric Content for Autodesk Revit 2013
» Revit Families_Using Content Created from Autodesk Inventor Professional 2011
