 Revit Architecture Conceptual Design Video Tutorials
Bài gửiTiêu đề: Revit Architecture Conceptual Design Video Tutorials   22/2/2013, 11:06
Here are a set of new Revit Architecture videos tutorials released by AutodeskBuilding on the 26th January 2011 ~ It's great that the Creating Custom Panel Series are numbered, but they should number all of these as the order presented by YouTube and uploaded is not the viewing order if you wanted to follow the series.
So to the creators of these 9/10 for the work you have done, just think about numbering when creating a mini-series of tutorials, because a newbie will need that assistance to know in what order to follow them. Then next time you will get 10/10
An Adobe White Paper from Autodesk on Conceptual Design may be found Here:
Introduction to Masses [1:56]
This video introduces how masses work in the conceptual design environment.
Mass Families and In-Place Mass Families [5:05]
This video discusses differences in working with mass families and in-place masses
Modelling a Mass [5:15]
This video shows how to model a mass within the project environment.
Building Parametric Masses [12:02]
This video shows how to build parametric masses.
Creating Mass Floors [2:19]
This video shows how to create mass floors and quantify square footage of conceptual masses.
Creating Schedules from Masses [8:07]
This video shows how to create schedules from conceptual masses
Modifying Masses with Parameters [7:11]
This video shows how to modify masses using parameters, using a sheared roof as an example.
Creating a Custom Curtain Panel - Part 1 [8:11]
This video shows how to create pattern-based curtain
Creating a Custom Curtain Panel - Part 2 [9:50]
This video shows how to create an adaptive component for a custom
Creating a Custom Curtain Panel - Part 3 [5:34]
This video shows how to use reporting parameters to adjust the width of a custom curtain panel
Creating a Custom Curtain Panel - Part 4 [6:20]
This video concludes the series on creating custom panels by showing how to load a pattern-based curtain family into a conceptual mass.
Creating Custom Divided Surfaces [4:43]
This video shows how to make a custom grid on a divided surface
Applying Divided Surfaces to Masses [6:05]
This video shows how to divide surfaces to apply panels to masses
Introduction to Pattern-Based Curtain System Families [2:58]
This video introduces how pattern-based curtain families work
Introduction to Divided Surfaces [3:44]
This video introduces working with divided surfaces
Introduction to Conceptual Energy Analysis [1:13]
This video provides an overview of the Conceptual Energy Analysis tools
Creating Settings for Conceptual Energy Analysis [5:11]
Learn how create and adjust settings for conceptual energy analysis
Conducting a Conceptual Energy Analysis [2:44]
This video shows how to conduct a conceptual energy analysis on a conceptual mass
Modifying Masses to Optimize Conceptual Energy Analysis Results [4:05]
This video shows how conceptual masses can be modified in Autodesk Revit Architecture software to optimize conceptual energy analysis results.
Comparing Conceptual Energy Analysis Results [9:15]
This final video in the Conceptual Energy Analysis series shows how analysis results of design options can be compared side-by-side in Autodesk Revit Architecture software.
Enjoy
» Không quân Mexico đã cho công bố một cuốn băng video quay cảnh 11 vật thể bay chưa được nhận dạng (UFO)
» Có thể đưa tín hiệu video vào monitor được không các bác ạ !
» phần mềm chuyển đổi các loại đuôi Total video converter 3.5 full
» Xin hướng dẫn chi tiết cách copy video ngoài vào đầu VTC HD-S19
» Quay video màn hình máy tính với Debut Video Capture Software 1.82 full vĩnh viễn
