 Download Autodesk Inventor Professional 2012 (x86/x64)
+5
tranphon01
tannguyen5584
danckm
hahahugo
9 posters
Download Autodesk Inventor Professional 2012 (x86/x64) Empty
Bài gửiTiêu đề: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime22/4/2011, 13:14
31.03.2011 By BKMetalx Leave a Comment
Khỏi phải nói thêm về phần mềm thiết kế Cơ khí quá nổi tiếng này rồi, phiên bản Professional 2012 với rất nhiều cải tiến đang đợi bạn khám phá Download Autodesk Inventor Professional 2012 (x86/x64) 71
Download Autodesk Inventor Professional 2012 (x86/x64) Inventor-2012
Info:
Autodesk® Inventor® 3D CAD software products offer a comprehensive, flexible set of software for 3D mechanical design, product simulation, tooling creation, and design communication. Inventor takes you beyond 3D to Digital Prototyping by enabling you to produce an accurate 3D model that can help you design, visualize, and simulate your products before they are built. Digital Prototyping with Inventor helps companies design better products, reduce development costs, and get to market faster.
Features
Easy to use and easy to learn, Autodesk® Inventor® software products offer a flexible set of tools for 3D mechanical design, CAD productivity, design communication, product simulation, routed systems, and mold design. With Inventor software, you can integrate 2D AutoCAD® drawings and 3D data into a single digital model, creating a virtual representation of the final product that can enable you to validate the form, fit, and function of the product before it is ever built.
Autodesk Inventor Professional 2012 Enhancements
Autodesk® Inventor® Professional 2012 software offers all the core features of Autodesk Inventor 2012, plus extended tooling, routed systems, and simulation tools to design, visualize, and simulate complete 3D digital prototypes.
Simulation Enhancements
Inventor Professional 2012 introduces new ease-of-use improvements to the simulation environment.
* Improved beam analysis
* Easily adjust joints in dynamic simulation
Tooling Enhancements
Inventor Professional 2012, one of the easiest-to-use injection mold assembly design tools, now allows you to add custom mold components to your libraries.
Other enhancements include:
* Mold-specific feature and geometry enhancements
* User-defined mold bases and mold components
* Improved integration with Autodesk® Moldflow® plastics injection molding simulation software
Link Mediafire:
http://www.mediafire.com/?mup24h8g3o1ht
Link File.qip.ru (Link cực nhanh, trên dưới 400kbps)
http://file.qip.ru/file/8fNGQEEO/x-force_2012_x32.html
http://file.qip.ru/file/Zdm-53f8/x-force_2012_x64.html
Tham khảo thêm tại đây:
http://rutracker.org/forum/viewtopic.php?t=3482759
Nguồn: Download Autodesk Inventor Professional 2012 (x86/x64)
- Blog Cơ Khí
hahahugo
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime5/5/2011, 10:42
có tài liệu gì về inventor 2012 không ạ
danckm
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime14/5/2011, 13:25
Lời cảm ơn chân thành dành cho thầy Thiệp!Người xây dựng web không vi mục đích lợi nhuận,thường xuyên dù ít những lời comment va bài viết được xây dưng bởi các thành viên.Xin tri ân cống hiến của thầy và website này.Mong thầy luôn giữ được lòng nhiệt huyết và chúc website ngày càng thành công!
tannguyen5584
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime15/6/2011, 16:09
download ve roi giai nen nhieu qua
tannguyen5584
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime15/6/2011, 16:14
lam cach nao cai dqat nhanh nhat thay oi!
tranphon01
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime8/10/2011, 20:21
bác ơi cháu tải về rồi mà cháu không biết phải giải nén như thế nào , bác có thể giúp cháu được không .
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime9/10/2011, 20:55
Bạn dùng Winrar để giải nén.
Sau khi giải nén, chưa phải là bộ cài đặt. Có thể bạn phải thực hiện tiếp:
+ dùng phần mềm FFSJ, nối các tệp đó lại thành một tệp có đuối là *.ISO.
+ Dùng phần mềm UtraISO để giải nén ra thành bộ cài đặt.
duccuong42
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime17/11/2011, 04:37
cháu down trực tiếp phần ở trang chủ autodesk phần dùng thử 30 ngày cho sinh viên. Qua google cũng search được 1 phần crack luôn. Nó có 2 phần 32 bit và 64 bit. Khi giải nén file crack thì chỉ file 32 bit chạy được, còn file 64 bit báo lỗi, không mở được không biết phải làm thế nào luôn. Ở công ti thì đang dùng bản inventor 2008. Mượn đĩa của tụi nó cài ra máy mình thì vẫn là bản chưa đang kí. Nếu export cái key của máy nó sang máy mình thì máy của nó mất key, không dùng được nữa, phải đăng kí lại qua mạng thì nhận được key lại và active thành công luôn. Nhưng mà ở máy mình thì cứ bật inventor lên được 1 lúc thì bị văng ra. Không biết bác có dành về vấn đề này không chỉ dùm cháu với.
Bản 2011 của bác ở đây download qua fileserve lâu qua, cháu down 1 tuần rồi còn chưa xong. Mỗi mấy tiêng mới down được 1 file, ngồi mải làm quên mất thế là down rất chậm, bác còn links khác không giúp cháu với. Mà không biết lúc crack có giống cái bản 2012 không tại vì mấy phần hướng dẫn bản 2011 với bản 2012 giống hệt nhau, chỉ sợ không được nên cũng không biết thế nào.
Thông tin thêm, cháu đang dùng máy laptop Windows 7 64 bit ram 3gb. Chạy bản dùng thử 2012 vô tư, mà bản 2008 toàn bị văng ra ngoài, chán quá đi. Đang cần quá mà không làm gì được, loay hoay mấy ngày nay rồi, ức chế quá đi.
duccuong42
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime17/11/2011, 04:51
Với lại bác cho cháu hỏi thêm, cái inventor 2008 ở công ti không có phần thư viện. Lấy đĩa cài riêng phần thư viện thì nó báo cái data manager bị cũ, nó không cài được luôn. Muốn insert mấy cái ốc, vít trong theo tiêu chuẩn, cháu không biết làm thế nào luôn. Trong khi phần Vault, với thư viện online thì bắt phải đang nhập, cháu lại không có ID password gì cả, không biết đăng nhập kiểu gì luôn, thành ra vẽ đến phần lăp ghép toàn để trông ốc vít, chán không chịu được. Trong khi bản dùng thử 2012 thì làm ngon ơ.
thang2810
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime19/12/2011, 14:34
Bác ơi? sao chau cai may cu bao loi: 'The Autodesk inventor 2012 installation path is longer than 109 characters. the intallation cannot contunue. Select a shorter Autodesk Inventor 2012 installation path.' Bác giúp cháu với ạ! Very Happy
thang2810
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime19/12/2011, 14:43
bac oi chau cai may cu hien loi:"The Autodesk inventor 2012 installation path is longer than 109 characters. the intallation cannot contunue. Select a shorter Autodesk Inventor 2012 installation path.". bac giup chau voi? Embarassed
tannguyen5584
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime9/2/2012, 14:59
bac oi cho chau xin lai cai link. link nay khong download duoc nua rồi!
huyktqs
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime27/3/2012, 07:58
Cám ơn thầy! Chỉ có những nhà giáo tâm huyết như thầy mới có thể vực dậy nền giáo dục Việt Nam. Link vẫn download tốt.
raiharu
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime2/10/2015, 22:33
thầy ơi link ko dowload được nữa thầy up lại đi a
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime3/10/2015, 10:39
Những phiên bản cũ này hiện nay không còn.
raiharu
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime3/10/2015, 16:08
thầy có phiên bản nào ko ạ
nếu có thầy có thể gửi vào mail xuantoiutc@gmail.com được không ạ
em cám ơn
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime3/10/2015, 16:25
raiharu
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime4/10/2015, 08:03
em cám ơn thầy
raiharu
Bài gửiTiêu đề: Re: Download Autodesk Inventor Professional 2012 (x86/x64)   Download Autodesk Inventor Professional 2012 (x86/x64) I_icon_minitime4/10/2015, 17:51
thầy ơi sao bản crack của inventer 2014 không dow được
» Revit Families_Using Content Created from Autodesk Inventor Professional 2011
» Autodesk Robot Structural Analysis Professional 2012 -
» autodesk inventor 2010
» Download Autodesk Inventor 2010 Tooling
» Plastic Parts and Features in Autodesk Inventor Pro Suite 2010
