 Mô hình Revit structure 2014 chuyển qua Robot Structural Analysis
Bài gửiTiêu đề: Mô hình Revit structure 2014 chuyển qua Robot Structural Analysis   19/8/2013, 16:55
Trong Revit Str 2014 không có chức năng chuyển mô hình sang Robot Str Ana. Các bạn phải tải toolkit này về và cài vào.
 Autodesk Exchange Apps
(Bạn nhấn đăng ký ID với Autodesk và tải về.
Dưới đay là chức năng của Add-In này:
Structural Analysis and Code Checking Toolkit 2014 on Autodesk Exchange Apps
The Structural Analysis and Code Checking Toolkit for Autodesk Revit software is a suite of tools that supports the Building Information Modeling (BIM) process and allows structural engineers to analyze and check their structure from within the Revit environment. It can be downloaded from the Autodesk Exchange Apps website for free.
[color][font]
[/font][/color]
Using this toolkit structural designers and engineers can optimize their workflows in the cloud and on the desktop by using the analytical model built in Autodesk Revit to conduct cloud-based structural analysis with access to Autodesk 360 services and by extending the Revit model to Autodesk Robot Structural Analysis Professional software or supported third-party analysis solutions.
Once complete, analysis results can be easily stored and explored in the Revit environment. Structural Results Storage and Results Exploration tools delivered by the toolkit enable users to explore and document results so they could gain knowledge on structure’s behavior, have insight in consolidated and detailed results, to take appropriate design decisions as well as properly document it.
Using the toolkit structural engineers can also verify and design structural elements according to local building codes and regulations which can be easily and quickly implemented by using the Code Checking framework. The goal of the new Structural Code Checking platform feature is to give Revit users the ability to perform a code checking process inside a native Revit model. The results of the Code Checking add-ins may be delivered in a form of Structural Results (visualized in a form of diagrams and maps), calculation notes, model and documentation updates.
Read more.
[color][font]
[/font][/color]
dohoa2006
Bài gửiTiêu đề: Re: Mô hình Revit structure 2014 chuyển qua Robot Structural Analysis   9/9/2013, 10:55
Thầy cho em hỏi :
- em đã cài RAC2014, nhưng kho cài RST2014 vì thấy modun RST2014 giống như RAC2014 ??
- Khi cài  Autodesk Exchange Apps bị báo lỗi .... như vậy có cần cài RST2014 không thầy.
Cám ơn thầy !
Bài gửiTiêu đề: Re: Mô hình Revit structure 2014 chuyển qua Robot Structural Analysis   9/9/2013, 15:33
Hai phần mềm này khác nhau chứ. Về dựng hình thì hai phần mềm giống nhau, nhưng phần phân tích và đặt tải thì chỉ có Revit Structure mới có.
Nếu bạn không muốn cài hai phàn mềm thì có thể cài REvit 2014 (phần mềm 3 trong 1, gồm cả Arch, STR và MEP).
Để cài được Autodesk Exchange Apps bắt vuộc phải có Revit STR,.
dohoa2006
Bài gửiTiêu đề: Re: Mô hình Revit structure 2014 chuyển qua Robot Structural Analysis   10/9/2013, 14:39
Rất cám ơn thầy ... chúc thầy luôn khỏe !
» 100% mạng truyền hình cáp chuyển sang công nghệ số trước 2020
» HD chuyển kênh bị mất tín hiệu
» Chuyển màn hình Laptop thành màn hình Tivi
» Giúp em chỉnh chảo K+ ở Thái Lan, Chiang Mai
» HTV nâng cấp lên DVB-S2 từ ngày 13-3
